Hi everyone!
I am in search of some thoughts and opinions here. Recently I acquired a PC from a friend whom just bought a new computer (and I think they got screwed, but thats another thread!) from a local PC shop. Their old (my new) PC Has a Gigabyte 7ZMMH motherboard, 128MB Ram, CDRom, and 20GB Maxtor Drive. Currently I am experiencing the system seeming to lock up while installing a new OS. (But never at the same spot, it varies.) I originally thought it was the hard drive and I had a boot sector virus that would cause this. I have run the drive under Autoclave (the 25 pass option) and tried installing, then I tried a different drive (a known good one I keep for testing purposes) and it did the same. My next step was to test the RAM using DocMemory and it passed. I still wasnt convinced so I replaced the current stick with a known good one (again, one I keep for testing) and I still had the same issue. Then I got to wondering about the CDRom. So I swapped that one out and still it would freeze. I have not tried replacing any cables because I figured that if it was a cable I probably wouldnt even be able to get as far as I do. So now my next thoughts are deeper and that it may be the motherboard or the processor. (The processor is an AMD Athlon 1.2GHz.)
I can boot and go into the CMOS just fine and boot and run the Ultimate Boot CD without issue but when Im trying to just set up a drive and install an OS (not doing anything fancy) it will lock up at some point.
So, now I would like to hear your thoughts and opinions as to what may be causing this. I dont have a problem buying a new MB or proc if needed (since I got the box for free to begin with) but if its a simple fix then WHOO-HOO!
Thanks!
Thanks!
