possible air in pump?
Bigbacon
I've had my setup running for almost week now and yesterday I started hearing the scratching type noise coming from the case. First I thought my crappy case fans were going bad as they seem to do alot but they are not. It was the pump. Every so often it makes another noise as if there was no water or something but I don't know exactly what to do. I shook the case a bit to see if it was air but that didn't fix it. Water still seems to be circulating with no problems.
Pump dieing? (hope not)
pump is Dtek dB-1
