Possible A7V8X-X problems?
-zax-
I just picked up a new motherboard and processor for a spare machine and am running into a few problems.
These are the basic specs for the spare:
- AthlonXP 2500+ Barton
- Asus A7V8X-X
- 512MB Corsair XMS PC2700
- 80GB WD SE
- VisionTek GF4 ti4600
I somewhat fixed the first problem last night, which was a rather hot processor, by removing the thermal grease from the stock HS and replacing it with AS5. It is still very warm, but running a bit cooler now. (From 65C to 48C). Also reworked some fans to improve airflow, and will throw in a 120MM next week.
There are two problems I'm running into now that irritate me. The first is that the board is only recognizing AGP 2X. I have updated the BIOS to the latest revision, which is v1012. Still no go. I have set it to Auto Detect in CMOS as well as manually set it to AGP 4X. Still doesn't work. I thought it might be a driver problem with the 4600. I had the 61.77's installed, so I went back to the 41.09's which didn't make a difference; then went back up the the 53.09's or something like that, and that also didn't make a difference.
I have no clue as to what to do next.
The other problem is when I'm booting up the PC. It boots up into WinXP ub3r fast, but then once it's in Windows, it seems like its trying to load drivers for a long time. I can do basic stuff, but when I try to open a program like ASUS PC Probe, it takes a very long time. Or even if I try to open something like CPU-Z, it takes a long time. I've used WinXP since I began beta testing it, and I've never run into a problem like this. I'm running off of a fresh install of XP as well, with SP1 and most of the crititcal updates.
I thought that the latest VIA Hyperion 4.53 drivers would fix the problem, but no prevail.
Anyone have any ideas??? This is very irritating.
For the bootup, run 'msconfig' from the run command. Check your start up items, make sure there's nothing that doesn't need to be there. You can also check your services. I'm sure a Google search, or maybe on the [H] there's a good guide to optimizing your services.
It's all running on a fresh reinstall of XP and it still does this. No other programs.
check in device manager there should be an AGP to PCI bridge, once I installed my mobo drivers incorrectly and it was stuck in PCI mode, see if anything has an exclamation point next to it under system devices(in device manager). For drivers I used the Via 4 in one.
had this mobo before and it died on me. not a bad mobo though but not the best. i had non of those problems with mine expect the agp thing. i reinstall all the driver of the mobo and the vid card and it worked perfectly. i also got a 40mm fan for the north bridge heatsink and it cooled it down a lot and helped a lil in performance also its going to be nice if u put a heatsink on the sothbridge because that could get pretty hot
I actually RMAed the thing back to ASUS.
gamer - I had all the drivers installed correctly. I usually start out by installing Win XP Pro, then the VIA Hyperion 4 in 1 drivers (4.53), then the ForceWare 61.77s, then sound... etc. Then I install SP1, and as of now... SP2.
It didn't read it right with or without the service packs installed.
I tried 3 different VIA drivers, as well as 3 different Detonator/ForceWare drivers, and still no prevail. I also checked in CMOS and tried to manually force to 4x, and also set to AGP video vs. PCI video. (Neither of the 2 options worked anyway :rolleyes: )
ati - Good call on the southbridge. I'll definately have to try and throw a HS on it to see if it'll help out at all. But as far as performance goes, right after I turn it on, it begins giving me the "performance lag" problems. I don't honestly think the temps of the north or southbridge get that hight that fast. But I could be wrong.
