Possibly upgrading my setup depending on what everyone thinks and what type of deals I can get on hardware. I'd really like to upgrade my monitor & get an SSD but I think it would stress my current rig too much which prompted me to upgrade everything!
Gaming 70% - Primarily steam/blizz games, D3, WoW, Sc2, possibly Tera, bioshock/deadspace etc
Browsing 20%
Plex Media server 10%
Value is most important, looking about a 1k build from what I can tell, but no real budget I guess, I just don't want to spend a ton because there isn't technically anything wrong with my computer right now so I'm trying to justify upgrading, debating on waiting until haswell but if I'm going Ivy I'd like to just do it now instead of waiting a few months and paying the same price 3months later
I may try to sell some of the old setup to offset costs.
I dislike MIR's but I can do them, if it's a good deal w/o getting the MIR back then I'm for it... Waiting on 2 MIR's right now actually.
Columbus, Ohio - Microcenter will be involved in this build
Monitor
CPU
Mobo
Ram
GPU
SSD
Corsair 550D(just bought, love it!)
Seasonic X-650
Samsung F3 1TB HDD
Sata optical
Asus DG soundcard (PCI)
6) Will you be overclocking?
I'd certainly like to if it's not too difficult, but I never have before.
AGNeovo F-419 4:3 19" monitor, but looking at upgrading this- so probably 1920x1080
I'd like to purchase a Dell u2412m, Dell u2312hm or one of the ASUS TN monitors such as this:
http://www.newegg.com/Product/Produ...236079&cm_sp=DailyDeal-_-24-236-079-_-Product
I can't really decide if it'll be worth it to get an IPS panel for my uses especially because the dells are 2x or 3x the cost, but as you can see I keep my hardware for awhile I've had this monitor since 2005 and it's been great, I think it was $230 at the time.
As early as tonight as late as the end of the month..
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing specific, I'm open to recommendations, possibly UEFI; it's beneficial for OCing correct? Don't really see benefits of more than 1 GPU and I'd prefer a cool and quiet system.
Yes - Windows 7 64bit
Current setup:
Board: ASUS P5KPL-VM LGA 775 Intel G31 Micro ATX Intel Motherboard
GPU: Geforce 9600GT
CPU: Core 2 duo E4600 @2.40Ghz
Monitor: 7 year old AGeovo 19" LCD F-419 @1280x1024
Memory: 2gb
Wishlist:
SSD:Crucial m4 128gb($125) or 256gb($190 @ buy right now tempting)
CPU:Intel Core i5 3570K 3.4GHz LGA 1155 -$190
Motherboard: GA-Z77X-UD3H LGA - $110
Is there a different one that I should look at? Any benefit of getting the UD5H?
Mobo List: http://viewer.zmags.com/publication/95f7a97d#/95f7a97d/27
GPU: 6950 2GB http://www.newegg.com/Product/Product.aspx?Item=N82E16814150549 (need to get on this asap if I want it)
Monitor: 23-24" ASUS TN or Dell IPS
Ram: Preferably 8gb kit, something with small heat spreaders but not super ugly
HSF: Coolermaster 212
Browsing 20%
Monitor
CPU
Mobo
Ram
GPU
SSD
Seasonic X-650
Samsung F3 1TB HDD
Sata optical
Current setup:
GPU: Geforce 9600GT
Memory: 2gb
Wishlist:
