Positive pressure setup killed my mobo
Chakachim
So I had been reading on the forums about this "positive pressure Idea". The one that if you have more air coming in than going out of your case, it would stay relatively "dust free". Well I tried it, and it totally worked, my case is completely dust free now, because it no longer works. :(
I had switched the rear exhaust fan to blow air in. watched my temps for a while, and only noticed like a 2-3 degree increase, not bad, I was fully aware that "positive pressure would increase my temps" so I was okay with it. So I load a game, and start playing, and completely forget to watch my temps. Well about an hour into the game my system locks up completely, Like to a dead stop no response at all. I go to reset it and I can feel the feat escaping from around the reset button. At this point I freak out. I take the side off my case and the heat hits me like a ton of bricks, its hot! like so hot that I immediately start sweating. so I put a boxfan on it and left it for the night.
So anyway, The next day I switched the fan back, and everything was okay for a day or two. I come back today to get on and its locked up again, I reset it and get to the login screen and locks up again, so I unplug it, wait a few minutes, plug it back in, it runs for maybe 10 minutes or so and locks up again, I reset it again, and now my bios cant find my Ide drives, so I reboot yet again and this time go into safe mode and all is well. It sees my drives, and it runs fine.
So at this point Im totally confused, why would it run fine in safe mode but lock up any other time? i havent installed anything since my fan "incident" so I dont think its drivers or anything.
Is it possible that my Chipset is burnt? since it usually runs the hottest, and is very under cooled (dfi stock fan :rolleyes: ).
What would be possible results of heat damage?
You can't be serious?!
Usually when people say positive pressure is better, what they really mean is, is that there should be more air going into your case than going out.
i.e FRONT/Side air going in > Exhaust/Top air going out.
But in your case it sounds like there's air going in but no air going out, no? And air going in with using the EXHAUST?
where's your Front intake fans?
So you're not taking the hot air out of your case which means heat starts to build up, and guess where the heat goes? NO WHERE. You're just circulating hot air around your system practically putting it in like a SLOW COOKER for your components to slowly melt. So there's your problem.
What case do you use? If you state that then I or another member can give you an example of how Positive Preasure works using your case as an example. Post a picture if you can.
Untill you grasp the concept, you need to switch gears back to the Maximum airflow style. Bonus points for using a boxfan, but dont have it too close as the magnetic fields may cause an issue.
ok, My case is the Superlanboy, I had 2 120mm Yate loons blowing in, one in front, one in the rear just next to the CPU. My Power supply which was exhausting, also has a 120mm fan in it as well with selectable speeds which where on high.
My best guess is that the fan that was directly below the powersupply was basically blowing in the same amount of air as the powersupply was exhausting, which left my front intake to have to force air out of anywhere it could.
Either way it sucks, and I think I fried my Mobo.
Sorry to hear of your misfortune.
Yeah, i would have kept the rear fan exhausting. Even though the power supply has a 120mm fan, it cannot exhaust as much air as the unrestricted exhaust fan on the back. So if you counted the PSU as 1/2, then you will have 2 fans blowing in, and 1 1/2 fans blowing out.
You could have damaged any one part or multiple. Who knows, maby the power supply is toast and not your motherboard, you just have to test them with known good parts until you find the culprit.
In the future you could add another 120mm fan blowing in (from the side window) on the hard drive bays to add more positive air pressure, but still keep the hot air going up and to the rear.
Don't beat yourself up over it hindsight is 20/20.
I bet one of your sticks of RAM is flaking out....
Try it with each stick seperately and see what happens.
Ram, was my first thought,So I ran it for hours with memtest 86+ with no errors. which thats another thing, itll run safe mode no issues, and itll run memtest with no issues too
test everything independently, it sounds like somehow you fudged your windows install if you can boot in safe mode without any issues. Fix your fans, you can use a filter to help cut back on dust a bit. Try re-installing windows.
The heat might have corrupted a HD... although I doubt it.
Try a reinstall.
Grr, now today it runs again. I dont understand, Ill prolly reinstall just to be sure
So I checked my Events and ive got like twelve hundred copies of this error.
"The driver detected a controller error on \Device\CdRom1."
And to think of it, it wasnt detecting that drive on boot either, could the heat have killed my cdrom drive? Or is it more likely that it smoked my IDE controller :eek: ?
If you didn't smell the smell of rotten eggs then there's a chance nothing fried. My suggestion to you is to check that the chipset fan works and reset EVERYTHING to stock settings. Afterwards do a clean install of windows and do some stability testing to ensure everything is running fine.
Good news, I unplugged my dvdrw and cdrw and things have been going well. Ive run Burn in test like 6 times already with no errors, no crashes. So Im assumming either one of my cd drives died or I have a bad IDE cable and possibly when I moved the fan back to the way it was I bumped the cable/
