balance101
- Jan 31, 2008
Hi after looking at some forum member post picture of their workstation/tower setups,
I'm just wondering what is the best position for the heat sink? or it does not matter?
front to back (intake from front and exhaust to back of case)
only con I see is intake memory heat?
bottom to top (intake from bottom of case to top)
con intake video card heat but cool air near the bottom?
i plan to use the thermalright Ultra-120 eXtreme in an antec P182 case
edit
another question antec p182 allows you to have 120mm fan in front middle intake and also to have another one in the end of the top hard drive cage, if i use both fan at the same time will there be a problem/less effective?
thanks
edit
thanks
