Posible Upgrade
Cri
Hi!
I,m thinking in upgrading a little bit my m-atx rig.
Actually I´ve got:
Cpu 939 Venice 3200+, Biostar 6100-M9, 1Gb Ram DDR, GF7800GT.
Actually doeing pretty well @2400 Fitted with a Zalman 7000Cu Cooler.
This could be a posibility:
Cpu Am2 X2 6000+, Abit AN-M2HD, 2Gb Ram DDR2 ¿Which Cooler?
Keeping the same Graphic card.
Do you think I´ll see any improvement?
Or have you any other suggestions?
Thanks for your help
Cri
Actually all is mounted in an Q-Pack.
Its quite a normal one.
Which cooler should fit? or should I just use the Zalman 7000Cu.
Thanks
