Portable keyboards?
atarumoroboshi18
Anyone have a good recommendation for a small foldable/mini/portable keyboard? Looking for a mini form factor keyboard for a few different use cases such as a couple of small devices and possibly to take with me on trips and the like. Any good ones I should be aware of?
I was looking at this Jelly the other day: https://www.amazon.com/Bluetooth-Je...1_4?keywords=jelly+comb&qid=1578084383&sr=8-4
I was hoping it was wireless vs. bluetooth but I guess you cannot have everything.
I think I saw a version of the same keyboard that did not have the mouse pad on the side and it was physically smaller.
I bought one of their small wireless ones (with a mouse combo) about a year ago and I beat the crap out of it- from traveling with it to pounding on the keys-- and it still works.
Here are some good mechanical 60% boards
https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=28
This is a HHKB lay out
https://hhkeyboard.us/happyhacking/
The nice thing about these boards is that theyre completely acceptable for home use as well. Theyre small but might not be as compact as a foldable. Also, this might be well out of your range as far as size goes in general. Most if not all are also a wired connection with the exception of the HHKB hybrids.
EDIT: Make sure to check for compatibility with your devices ( HHKB ).
Not exactly portable, however, I own three of these bad boys and they are pretty damn sweet (and backlit): https://www.amazon.com/CORSAIR-Wireless-Mechanical-Keyboard-Backlit/dp/B077ZX9KJ7
What you lose in portability you gain in responsiveness, and if you want to lug the lapboard with it, flexibility.
