XLeezardx
[H]ardChef
- Apr 30, 2005
Is open better or Closes?
Sennheiser PX100 or Sennheiser PX200?
Please help me choose thanks!
HAHA. That question is 110% subjective.XLeezardx said:Is open better or Closes?
towert7 said:HAHA. That question is 110% subjective.
That's like me asking what is the better sports car, the red one or the yellow one ^_^.
Anyway, if all else is equal, I would vote for the open because it lets air in and out, which will keep your ears cooler and as a result you might not get as much of a "swamp effect".
As always though, go and try them on and listen to them and see for yourself.
~Hope this helps
strid3r said:but Headroom seems to like the PX100 more:
http://www.headphone.com/products/headphones/earpad/
I was'nt touching upon sound quality, but rather the prefrence between open and closed with respect to things like isolation.strid3r said:Not quite, open headphones generally sound better than closed headphones.
NopeHave you used either of the PX100/200s?
towert7 said:I was'nt touching upon sound quality, but rather the prefrence between open and closed with respect to things like isolation.
If that made no sense, basically I was just saying some people want to be isolated from their surroundings, and others don't need it.
You are right though, most times you get a diffrent sound from open just because of the spaciousness. It sounds less "in your ear."
The PX200 is a supra-aural headphone (rests on-ear), so it probably won't provide much isolation. If you want isolation, then you'd want canalphones or sealed circumaural headphones (like the Senn 280s).unhappy_mage said:It depends on your application; you will be better off with closed phones if you're in a loud environment where you don't want to hear the noise. Open phones are good for walking around in so you can hear traffic etc, or places where you might need to hear the phone ring or whatever.
