portable desktop build or laptop?
silk186
I'm not too sure if this is the right section to post my question but here it is.
I will be going overseas to work in different countries for 6-12 month periods. I would really prefer a desktop over a laptop for performance, upgrade options, ect. but I'm concerned about transporting it. I want to build a decent system, quad core (some overclocking), mid/high-end video card or SLI/crossfire, 4gb ram, 22-24" LCD and some kind of near silent cooling arrangement. I can see how cooling would be an issue in transportation so I would either need use liquid cooling and drain during transport or passive cooling and remove the heavy heatsink(s) during transportation, and of course some quiet case fans.
I'm thinking that I won't be able to use a very small tower with this kind of build do to space requirements and air circulation, though smaller would be easier and cheaper to move. What size case, or specific cases would people recommend for this kind of a build?
The second question is about the cost and safety of transporting. Anyone have experience with this? Did you transport in the original packaging? dismantle the system and package the parts separately and box together?, stick the case and screen in your suitcase wrapped in clothes or stick it in a special box marked fragile? If you have tried any of the above options or another what were the associated costs?
Is it possible to take the tower on the plane as a carry on in some kind of lan-party case/bag?
Am I just asking for trouble? Should I just give in and buy a laptop overseas (Taiwan/HK/Beijing?) and use an external mouse, keyboard, external HD and possible a cheap LCD? I'm not really sure what the cost/performance ratio is between a laptops and a desktop build or what laptop panel quality is like.
I know people move their rigs around for land parties but an airplane is a little different.
I'll be using the system for internet, word processing and watching movies (hopefully Blu-ray depending on what I can find in the region). I might also use it to watch TV through a tuner if I can, and play games. Some shooters (not crysis) and mostly action RPG games like Witcher, Oblivion, Startcraft II and Fallout 3 when they come out.
I've been looking forward to upgrading after I finish my degree from a P4 2.6, 1GB ram and nvidia 6200 with a 19" CRT Samsung SyncMaster 995DF. Even a decent laptop will be a big performance jump but I was really looking forward to building a new rig.
Any advice would be greatly appreciated,
Thanks in advance.
A gaming lappy would prolly fit your bill if you are moving a lot. But the cost for the performance is still pretty bad. As far as shipping a regular prebuilt pc, the box it comes in was designed to survive the 800lb gorillas that work as ups, fedex, and the us postal service. As long as the original packaging is in good shape it should be ok to ship it in that. As far as removing heat sinks, it should not be necessary, as long as you are not going with some massive all copper jobs on everything. Which you really don't need unless you are doing a lot of ocing. If you are building your own go for a case with a card holder from a quality brand and try to use oem heat sinks.
I agree, a gaming laptop would be much easier to lug around.
You could build a small form factor system, like with a MicroFly case, or pickup a Shuttle barebones.
A friend of mine brought one of his old computers overseas to donate to his little cousin. He didn't even box it up -- just carried the mid-ATX tower on the plane as a carry-on item, lol.
