Port logging
k1pp3r
What programs do you recommend for logging ports used on a server? MSParser doesn't run on SBS running DNS for some stupid reason. Currports has no installer it just runs.
What do you recommend using for port logging on a SBS 03
netstat > c:\log.txt
can't run as a service. I'm having an issue around 1 AM and don't want to be up running netstats, or restart it if the server reboots for some reason
Win Firewall should get the job done
create a batch file with:
date /t >> C:\netstat.log
time /t >> C:\netstat.log
netstat -a >> C:\netstat.log
create scheduled task(s) to run
that would be the best way if using netstat, anyway.
I'm not sure if TCPView by SysInternals has any sort of logging that can be done...
It's not appropriate for just one server, but for monitoring many servers and their services OpenNMS does this great.
