jay2472000
- Oct 6, 2008
Network setup is as follows
Internet--->Westell 4 port gateway /wireless acces point /router ---> internal lan
Im using 3 of the ports off the Westell and the wireless access point. Using DHCP but soon to change that.
Right now I am just fiddling with some stuff from outside my network for the first time and have fowarded some ports. One example is a program called Yawcam that I fowarded port 8081 so that I can use my smartphones browser to log in and view my home from abroad. The webcam software has a captive portal set up and I have it configured with a username and a strong password
I have also been goofing with webpage design a little and set up a very very simple webpage on my freenas. So by typing my in my Ip and the correct port it displays my directory. ( I did change it from port 80 just to make me feel a little safer)
So how much have I opened myself up to a potential security risk? Im assuming the webcam software is ok, IE its as strong as my password and username combo.....assuming theres not some odd backdoor way into it. Im really a little more concerned with putting my Freenas box on the web. Should I go ahead and rebuild my pfsense box and put the webserver on a seperate Vlan?
Just looking for a little guidance as I have never before opened my lan up to the web. Thanks in advance, J
