I have port forwarded the port 6112 for Starcraft on my Buffalo router when I had Comcast and I did it for my friend's Verizon FIOS also. The Buffalo router burned out after years use and I switched ISPs because my sister ordered some cheaper package..
I had to change the Local IP Address to 192.168.2.1 instead of the default 192.168.1.1 because the DSL uses that IP address for their own basic setup.
I set the static IP address to 192.168.2.102 and have port forwarded that exact address but when I go to Status on the Linksys menu, it says my IP address is 192.168.1.47 and I checked that in my Verizon DSL setup and that is the address I have..
I have a Westell Model 6100F modem for Verizon and a Linksys WRT54G2 router.
I normally follow the instructions here http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G2/Starcraft.htm but it doesn't work here.
