Hello,
I'm looking how to forward ports in Vista since the steps have changes a little.
I've already gone through the usual way of identifying my ip adress through "run>command>ipconfig /all" however, it reads an address that is about 28 digits. I'm looking for an ip address that falls somewhere around the lines of "10.0.1.xxx"
I've also noticed, in the process to make a static IP address, the options look alittle different compared to XP. (no subnet mask etc...)
If anyone has successfully managed forwarding ports through vista, i'd appreciate it a lot if you help me out. Thanks so much for your time.
