charlesshoults
- Mar 18, 2008
I'm working on a relatively small wooden computer case, right now to house Windows Home Server components but with Microsoft apparently killing off WHS, that may change, possibly to Amahi or UnRaid.
For now, the thing is up and running:
ECS H55H-I
Intel i3-550
Crucial Ballistix DDR3-1600
Coolmax 500W psu
The computer case will have two trayless SATA enclosures for a total of eight drives at the bottom to keep the weight low and attached to two aluminum plates, one above and one below. The motherboard then mounts above the drive enclosures with the power supply at the top.
12.75"W x 11.25"D x 17"H
All of the wooden panels will be connected using dowel pins and glue instead of screws so that it can all be sanded flush.
The center section panels have vertical slots routed on the outside and horizontal slots on the inside, foam filters secured to the inside of each panel.
The case is shown here with motherboard and power supply centered. I'm not sure if they'll stay centered or moved to one side or the other.
ECS H55H-I
Intel i3-550
Coolmax 500W psu
