I just setup a new rig and running a Sapphire X1800XT (speced at 625 core / 750 mem) . .
I've read some 'guides' on OCing these cards, so disabled the 2 ATI services (smart and hotkey) . . also disabled the ati... entry from startup.
I'm using ATITools v .25 beta 14 (latest beta) . . It detects my "default" speeds as 593/694 (why??) . .
Anyway, I CAN run at 623/747 (which is what its rated for) no problem . . basically ANYTHING over these settings I get lockups or artifacts.
I checked voltage (within ATITool) and core GPU voltage = 1.275v and mem voltages are both = 2.097v
Whats the deal? I see all kinds of posts/reviews/articles hitting well over *stock* speeds . .
I have uninstalled drivers (using ati's uninstaller) as well as removing all entries from add/remove. I'm using 6.3 Cats FROM ati . .
I may try using DriverCleaner tonight and then install Omega's based on the 6.3 Cats..
Anyone have any suggestions? Is there a better way to do this? Am I missing something?
