Ok so background on setup first. I have an all-in-one ESXi setup using ZFS for a SAN as a guest machine. I have 2 Server 2012 guest machines on the host.(each with 2 vmnx3 nics with RSS enabled)
I wanted to play with SMB3 and multipath and see how it works. So I created a COMSTAR iSCSI volume to mount on one of the Server 2012 VMs then I shared that mount point within the guest. (Yes I know there is overhead and I could share the drive directly from ZFS but then that does not support SMB3)
To get a baseline performance of the iSCSI volume within that VM guest I ran crystalmark and get ~400MB/s seq. read and ~340MB/s seq. write. About what I would expect.
Where this goes bad is from the other Server 2012 guest I only get ~80MB/s seq read and ~90MB/s seq write.
I have confirmed that RSS is enabled on both machines and that it is using the multiple connections. But heck I am not even seeing performance that I would expect from non-multipath let alone multipath.
NOTE since these tests are done within the VM it eliminates and switch or wiring issues and ESXi with vmxnet3 drivers should get really good network speeds between guests.
Any ideas? Thanks
Any ideas? Thanks
