Poor SATA performance on CFX3200?
xappie
Hi all
Since I started using this CFX3200 motherboard, I have noticed that the HDD performance with my WD Raptor 74GB doesn't seem to be as fast as it was with my previous DFI NF4 board. I have tried both SATA controllers, several driver versions, and using only the windows drivers but I still see a noticeable decrease in HDD performance. This is most noticeable when windows is loading up and when I am loading games. Games that I have been playing for a few years now (ie WH40KOW etc etc) load noticeably slower.
Is there anything I can do to increase the performance of my HDD? Is there something specific about my configuration that is causing this?
Any advice is appreciated!
What BIOS do you have? Over at DFI-Street forums people have complained about this issue and a ULI southbridge update seems to fix the problem. The latest BIOS(0728) is quite good and Raid performance it about on par.
Not sure what is causing it, but from having done testing on Xpress 3200 Crossfire compatible chipsets, I can say that the performance should be within a few percentage points of the comparable nForce 4 solutions. Your situation is definitely not normal.
Not that it helps much for me to say that.
Did you get the latest drivers for your motherboard? Latest BIOS? Firmware updates on the drives?
I am using the 7/28 bios and I tried all the non-beta drivers I could find, and I am not running RAID.
I hadn't thought about a firmware update for the drive though - they do that? I will check it out.
Edit: Nope, no firmware updates for my WD SATA drives.... fromt he WD site:
"Serial ATA Drives
* There are currently no firmware updates available for Western Digital Serial ATA hard drives."
I am using the 7/28 bios and I tried all the non-beta drivers I could find.
Yes they do. It's unusual to have to do one, but I've run into it a few times over the years.
