Guys, i've lapped my U120-E & Q6600's IHS ...with 150, 400, 800 grits of sand paper...for the CPU i did dry sanding....
at 3.2ghz, 356x9, 1.375v....used zalman's STG1 thermal grease, which i followed the manufacturer's instruction of putting a coat on HS & another on CPU.....my idle temp is like 47, 49, 43, 43.....under prime95, large FFT max heat test, it goes up to 63 63 58 58..... it used to be like 67 67 59 59.... why's my idle temp & load still so high ? the room temp is around 70F...no higher... should i have gone higher than 800 and used 1000-2000 grits to finish it off ?? i mean i saw in the sticky guide people using 1000-2000 grits.... i just forgot to pick those up during my trip to walmart... :-/ could it be the reason why the temp was still so high ?
