I recently put together an E6400 system that I've wanted to overclock. The hsf is a Zalman 9700, and the mobo/mem combo is in the screenshots below. I can't get Orthos to go more than 12 seconds or so without errors with my fsb at 340. The error is always a rounding error. At 330 and 1.3875 vcore, it went about 20 minutes with no errors (I know 20 minutes isn't enough to know definitively, but enough for each 10 mhz increment). Idle CPU is about 47 C, and 53 during the Orthos testing at 330. Here are my current BIOS settings:
CPU Voltage: 1.4125
FSB Term Volt: 1.3
MCH Volt: 1.35
Mem Volt: 1.8
Sys Mem Freq: 533 mhz (1:1 ratio)
PC Health section in BIOS says:
1.39 vcore
1.47 nb/sb voltage
From what I've read, that should be plenty high for 340 mhz fsb, and heat isn't a problem. Ram is 800 mhz, so it shouldn't be crapping out at 680 mhz. Any suggestions?
CPU Voltage: 1.4125
FSB Term Volt: 1.3
MCH Volt: 1.35
Mem Volt: 1.8
1.39 vcore
1.47 nb/sb voltage
