I've got a network setup here at home. Following is an image depicting my network setup.
http://i49.photobucket.com/albums/f287/chrisfnet/network-diagram.gif
I'm running Windows XP Professional on my desktop machine. It's connected at 1Gbps. I've got 7' Cat 5e run from it to the switch. I've been testing from a SATA-300 drive to try to eliminate the drive-read limitation as much as possible.. though as low as my performance is.. it wouldn't matter anyway.
I'm running Ubuntu Server on the other machine. It *says* it's a BCM4401 NIC (Broadcom) and by all specs I've seen it supports Gigabit speeds. However, I see no place to negotiate 1000. So... I'm not sure.
At any rate, I'm only getting large file transfer speeds of about 4MBps which bothers me. Even if I were using IDE and 100Mbps.. I should be getting more than 4MBps!
I have jumbo packet transferring on in Windows XP as well.
Any tips/hints for diagnosing and fixing this?
