I've run through all the basic troubleshooting with ATI support and they've now told me to come to the forums to find a solution...
The problem:
Over the HDMI connection:
1) Colours appear washed out, or overly bright.
2) Text is difficult to read/ annoying/ blinding after long use.
Here's the story:
I've had this problem since December when I bought a new Westinghouse L2410NM 24" monitor:
http://www.westinghousedigital.com/details.aspx?itemnum=105
The monitor has both HDMI and DSUB connections, and I noticed that the DSUB looked strikingly better at reproducing colours and also made fine text much more readable when hooked up to my HD2600XT.
Interestingly, the same problem occurred with a Nvidia 8400GS i also had around. (The HDMI connection had the exact same poor image quality as the hd2600xt). However, I was able to fix this using the following driver hack:
http://forums.nvidia.com/index.php?showtopic=58483&view=findpost&p=330319
Which involved editing an .inf file before installing the Forceware drivers.
Finally the Nvidia 8400GS was displaying perfect image quality over HDMI, unfortunately, my more expensive HD2600XT is still not capable of giving me good HDMI image quality.
Can anyone offer a suggestion how I might modify the Catalyst drivers to get my HDMI quality on par with my Nvidia card, or even the DSUB from the same card?
I have uploaded a full size demonstration of the difference between the HDMI image quality vs the DSUB image quality here:
http://www.megaupload.com/?d=CXNIHYOS
Smaller versions can be found below
Take notice to:
1) How the colours change within the different lands on the map.
2) How the black text on the left side is much easier to read on the DSUB picture.
I've also found another person who is having the exact same issue with this same combo of video card and monitor:
http://www.avsforum.com/avs-vb/showthread.php?p=13142644#post13142644
DSUB
HDMI
The problem:
Here's the story:
Take notice to:
DSUB
HDMI
