Poll: DS3 or P5B-E for me?
Which mobo option???
  • Total voters
    43
gorilla show
Ok, everyone, please help me choose my motherboard. i have narrowed it down and come up with these 2. If you have other suggestions please list them since I am not certain these 2 are the best...:D
i have 2GB corsair PC6400 4-4-4-12 and e6300 waiting for a mobo. Vid card will come later...
Either should work fine.
My DS3 works fine up to about 474Mhz. And has been a charm to work with since the F7 bios. Before that I couldn't run lower multipliers with high FSB's for some reason.
The P5B-E should have the C2 stepping 965 Northbridge since its newer, which is probably why people have slightly better luck at hitting 500FSB.
flip a coin, they're both great boards.
I have a DS3 and a P5W and both are good boards. Depends on the features you're looking for. Either one should clock about the same.
I apologize for the threadjack but has the micron D9 problem been resolved with the DS3 yet?
D9 issue to be resolved in the upcoming F8 bios according to some over on XS forums I believe (Lestat was the one I believe I saw mention it). And the only "issue" really with D9 memory is that it won't allow the insane clocks it's capable of, but still hits mighty clocks as it is on F7 from everything I've seen elsewhere.
I voted DS3. Love mine so far, absolutely. I have no doubts it'll allow me to push this 6600 as far as it can go and won't end up limiting the chip before the chip finds its own limits. Right now I'm held at 3.4Ghz on a 6600, but only by my cooling solution, I know 3.6 to 3.8 will be doable once I go to a quality liquid cooler as I've gotten to 3.6 already and get it to run benchmarks, tho it's not prime stable on core 0. Temps are the hold back as I hit 72-73C under Core Temp and while more vcore would obviously stabilize it, temps are too much to allow more vcore at this point. So, cooling is my only limit with this board as I see it to reach my goals. That's a damn fine board in my book anyday.
My vote is p5b-e. I had to return my 945p-s3 due to it not recognizing my compatible ram after 3 weeks. I was like WTF??? Plus I was running a Zalman 9500led and the motherboard seemed too "thin" to support it.
gwarren007
chrisf6969 said:
Either should work fine.The P5B-E should have the C2 stepping 965 Northbridge since its newer, which is probably why people have slightly better luck at hitting 500FSB.
Yeah, thats what AndreYang at XS made it sound like but surprise! when peeps got boards only to find out there was no C2 to be found...
Is there some reason why you arent considering the Biostar Tforce650PT? I've only seen a few results with it, but it seems 500FSB out of the box is obtainable
I am a big fan of their 754 and 939 mATX Tforce6100 boards, but I never heard of this one, can you send me a link? :D
lol, this is what i should have said:
can you send me a link to performance related stuff for this board?
sorry :p
i have a gigabyte s-3 for overclocking it is reasonable priced and overclocks very well . my 6300 is pulling 480fsb stable on air cooling .
i have heard of very good results with the biostar i would have bought one except they wern't retail yet when i wanted to buy .
if your primary goal is a good OC and a stable system which is more basic in nature--these two are tough to beat . :cool:
Go with the P5B-E....I just set up my new rig and have the P5B in it. I had no problems what so ever with the board. I have read reviews about the DS-3 and its northbridge not staying cool and being to hot to touch. The P5-B has reasonable OC'ing and is a good stable board. I have an E6400, 7900GTO, 2G of Corsair DDR2 800 memory. It comes with a nifty little connector for all of your case front connectors to the board w.o having to hook them up and guess on the wiring. Personally...I would pick the Asus P5-B again. I liked the setup and everything about it enough I wouldn't consider trying another one. But, it's just my opinion.
Asus generally makes better boards than Gigabyte. This has been my hands-on experience, and I have seen this opinion in many past reviews.
Gigabyte finally has a good intel board on their hands, but I would have got the P5B-E if they had it at frys.
