Geo Fry said:What is the best way to polish aluminum to a near mirror finish? like how fine do i need to sand it? what should i use to buff it with? what kind of polishing compound should I use?
Thanks Geo
Rhentno said:If you said you had three sheets of sandpaper...you're gonna need a bit more, alot more actually.
Geo Fry said:And this is after wet sanding with 1000grit auto sandpaper and one time through polishing compound:
I'm going to try polishing compound a few more times... but I might need 1500 or 2000 grit to get any more... although I'm not looking for a mirror. What I have now is pretty close to what I want
Geo
^^^ - QFTjreffy said:Your polishing compound won't get you anymore shine. You've got to go up to 1500 and 2000 grit sand paper. Then once you've gone through those once, start over and go from 800-2000 all over again, and then again one more time.
You've got to give it a full wet sanding treatment 2-3 times up to 2000 grit to get that real mirror finish. THEN use your polishing compound as the very last step. That should only really need one application.
jreffy said:You're going to want to go pick up sand paper ranging in grit from 600-2000. I found 600 and 800 at the hardware store, but you'll have to go to an automotive parts store (Pepboys) to find the higher grits.
Yeah, it took me a while to find it, but they do have it in the automotive department... along with some cool paint's too!aburgard said:Or the Walmart automotive department...
