asrock g41m-vs3 r2.0
gtx460 sc
core quad 6600 2.4ghz clocked to 3.0ghz
8gb g-skill 1333
wonder if anyone has an idea what ive done wrong
ive been running my gtx 460 through a 26"polaroid lcd tv (tlu-02612c)
for the last few years via vga cable with a dvi adapter now when i turn it on it flashes blue an gives me no signal plugged into a smaller pc monitor works fine ,took out the gtx 460 an tried a really old ati card the dvi didnt work but it had vga an it worked.before this happened i had been having some trouble with bsod namely ntoskrnl and hal.dll and one nvlddmkm.sys so theres been a couple of re-installs of windows an a bios update for the board occasionally id pull the vga out the monitor an pop it in the back of the 26"and it would come on for a while then eventually it would blue screen any ideas would be much appreciated
gtx460 sc
8gb g-skill 1333
