Google Translate
specs on P11 rumor
specs on P11 rumor
1280 shader units, 80 TMU's and 40 ROPs. The GPU does its work at about 1 GHz, which is much lower than the (higher positioned) 16nm models from Nvidia. There's 4GB of GDDR5 memory available, which has a 128-bit wide memory bus is controlled. The R9 470X must therefore perform similar to the R9 380 / 380X, though AMD has the TDP of the card while it heavily in know constrain. According to Chinese sources, the R9 470X has a TDP of only 60 watts
