I'm an IT professional and have a Cisco 3560G POE switch at home (WS-C3560G-24PS-S). I want to replace it with something cheaper. It may sound counter-intuitive to do so, but I really don't need the features it provides and it's getting long in the tooth.
Problems:
It is loud as hell and you can't slow that 4-pin blower down. It's in the basement, but still....annoying.
It's POE is only 802.3af.
It has shared ASIC's for groups of 4 ports - so I have to wire my devices carefully.
What I am looking for is something that has at least a couple 802.3at (30W) POE ports, much quieter (doesn't have to be fanless), better overall throughput and at least basic L3 static routing. 24 gigabit ports. I want to use this switch as my default-gateway for all my devices, not the upstream firewall. That's all the routing I needed in the 3560. And it has to have basic smart switch capabilities - vlans, 802.1q trunking, routing between vlans, SNMP, port-spanning capabilities.
Price is of a concern. I don't care if it's only web based. Any recommendations? I'm looking at Netgear, D-Link, Zyxel and the like. Not HP, Dell, or anything more expensive. Right now, this Netgear switch seems to fit the bill, but welcome feedback or other choices.
Problems:
