I recently bought 2 trendnet 200Mbps powerline adapters, and they work pretty well for simple things.
My question is: Can you use PoE through them?
I read a post here, and tried googling information on this, but didn't find anything. The only thing I found was in that last post, where they said it should work but not through the adapters themselves (in that link, someone says to make sure the PoE injector goes between the adapter and the device, along the cable. I was wondering if you could run PoE through it, and have it come out the other end, and power something. I know a PoE injector would work on the cable run that exits from the adapter (theres no reason it shouldn't), but does anybody know if I can inject PoE on one end, have it travel through both powerline adapters, and power whatever PoE device on the other end?
Most of you are probably thinking "What's the point, when you can just plug a PoE injector into the outlet that the powerline adapter is in?", but I want the other end to only have the device and the powerline adapter *only*... not a PoE injector also (I could just plug the device into the same outlet, in that case).
Thanks.. been wondering for a while now, and didn't want to test it out myself and it not work
