Podcasting = soundcard?
Mayhs
Ive started doing Podcasting recently, its where you download from a live music stream from a radiostation over the internet e.g hot 97.7 (something- i dont live in america :p )...anyways i can do it fine at 128kb but when i try 320kb the sound quality is WORSE...is this because my onboard sound is incapable or is it because my software is bad?
Thnx
Mayhs
Thnx
Mayhs
3 things :)
1.) What is your onaboard sound(chip)?
2.) What software are you using?
3.) Sure you are getting all the packets from the host?
If it's live-streaming, perhaps their/your/combined/ bandwith jus't isn't good enough at the time?
Terra...
Terra said:
3 things :)
Terra...
hey :)
1) on the a8n sli deluxe motherboard its the realtek audio97 or something...
2) this software i got from a dvd called 'alive wma/mp3 recorder' - and yes ive set it to record as mp3 :)
3) and the bandwith was fine i suspect...i was testing it at a time which is quite unpopular for the radio station as i thought this could be a problem but it was the same at different times in the day
another question
i read a post about someone saying that onboard can only play upto 128kb sound? because i dont hear much difference from my 128kb music and my 320kb music :(
I have never heard of a soundcard or onboard being unable to play music above 128kbps
Maybe what you saw was that someone's onboard was so terrible that they couldn't tell a difference
well to tell you the truth i have some 320kb music and some 128 and the difference = not much BUT i am currently on really bad speakers (my z-5500 broke getting another pair this week)...
what do you think about the podcasting?
Mayhs said:
hey :)
Okay, the old AC97...it should handle yout music fiine., but that's also it.
Okay, I usually use this software: http://www.litexmedia.com/?from_WMAWorkshop
You do have the current drivers, and set the software up to encode it proberly?
another question
That depends a lt on your speaker config and you soundchip.
But I have no experince with that AC97, excpet that it sits disabled on my mobo *L*
But it shouldn't have any problems with 320 kbps MP3, that I am aware of.
Terra...
