PNY Quadro question.
Just checking, you are planning to do CAD with that Quadro not games right? I've seen a few people who think Quadros are the way to go for games....and I did not see the phrase "This product is warranted through the product manufacturer only" which implies to me that it has no warranty....don't know for sure.
3D rendering, and yeah I read that but that means no warranty from newegg its the same with the retail quadros, Im wondering about PNY.
The 3450 is close to 3 yr. old. They are totally out dated and cost more than the 7900GTX, which is cheaper and much faster, better performance, and more quiet.
Also PNY warranty service is one of the worst. Do a search under "PNY RMA" and you'll see for yourself
Exactly, thats what I heard anyways, they care more for their Quadro lineup and customers.
But my question is if the OEM versions have the same warranty as retail ones.
Also, anyone with experience on this card ? This is as much as I can spend on this and its the only one available is it good enough for maya rendering ? Im in desperate need of one, probably pairing it up with an AM2 Dual Core setup.
The OEM should carry the same MFG warranty.. not 'in store' warranty.. I think typical in store warr for OEM is 30 days. After than it's MFG only.. with those cards, I bet the turn around would be pretty fast, if something did happen. I think they test them a lot more thoroughly. Well, I hope they do at least.
whew.. 900 bones (after tax) for a 12 pipe card.. That's a lot. :)
:p I know, too bad 7xxx cards blow in maya.
Anyone know what are the benefits of going SLi with these cards ?
