Well let me start by saying I was anxiously awaiting for this card to be delivered..the day I got it and installed it on my system(see my sig) I noticed that when booting ,the screen flickered and noticed the bios screen loading very slow , then while trying to boot up too windows the screen would go blank. So I unplugged the pci connector and reconnected and again the same thing happened but it was able to load into windows now.So I installed latest nvidia drivers from 3d guru and everything goes well except the flickering still continues when I reboot the computer and the bios screen loads slow and flickers. Then I installed riva tuner and note that the gpu temp is 70c,is this normal? Anyways I leave the computer on and leave my house for a couple of hrs..when I return I note my computer is turned off!! And im like wtf? So i try to turn it back on and it just wont turn on.I could see the fans try to make a turn but stop and nothing turns on.. So I said to myself my psu is more than sufficient for this video card. So i go to best buy and buy a bfg 850w psu and come home to install it and the same thing happens..nothing turns on..well I then take off the 8800gts and put back my 7900gs and now the computer turns on and working well.
So my question is IS MY 8800gts Dead? or what else could be cuasing this problem?
