pny 7900gs O/C oddness
jpangelo
I'm used to tweaking everything. So when I get this Pny 7900GS, with a NV5 silencer on it, off our fine FS/T here, it runs at stock fine, but me being me, I run coolbits, autodetect, and get graphical glitches on desktop- little horizontal splotches. Then it starts to turn vid off every few seconds, and the only way to make it stop is to reinstall the driver. Should I just accept that this card doesn't o/c, or is there something I'm missing? PSU is a 650W with 52A on 12v rail, cpu is a 4000+, on a kn8.
thx for any help
perplexed
i'm guessing you don't have 52amps on the 12v rail
what psu is it?
and yea you're probably going to have to live with it or volt mod it
Coolbits autodetect doesn't always work right.
Use Rivatuner (get it from guru3d.com)
Also... there a few chips on the back of the card that get extremely hot. I used some ramsinks to cool them off on my 7900GS.
Do a google search on 7900GS or 7900GT volt mod... the ones that show pics should show the chips that get extremely hot (even at stock temps).
If not.. you can always just leave the side off of the case and feel the chips on the back of the card (all on the end of the card that has the power plug). There should be 3 total that will benefit from ramsinks.
its only with coolbits, when I hit Autodetect. I can use AtiTool to overclock, either mem or core, and it works without corruption. But if I hit Autodetect in the drivers via coolbits, horizontal lines of corruption fill the screen.
odd.
