PM "huh what?"
Status
Not open for further replies.
ashmedai
It temporarily said "Your private message box is 100% full" (or something close to that). It went away (and the cap is elsewhere listed as 300).
What gives, and should I care? Do you need to care?
Who knows, but I thought I'd share in case it was symptomatic of something going boom that might need attention.
Thanks!
edit: probably is something different from what I got,
so nevermind
Thanks!
your a genmay subscriber right? so you get the 300 pm limit.
i believe it has to do with this
http://hardforum.com/announcement.php?f=116&a=83
specifically this
(genmay only)
http://hardforum.com/showpost.php?p=1032878919&postcount=48
It sounds like it could do it. I take it the normal threshold is < 60? :D
delete some of that crap out of you box so you won't have any more problems. this aint gmail.
Status
