I wanted to RAID 0 2x 150GB Veloci but now I decided to go with the new 15.6K 146GB Cheetahs instead and i need a reliable RAID controller card that will work with XP Pro 32 and my nforce590 board. Problem is there arent any reviews by online publications for the cards i'vc seen at newegg so i selected a few based on reviews there. If anyone here is familiar with those or wants to recomend something else, plz do. I don't want to spend more than $350 on it. I'd prefer a PCI-e card as i have an empty PCI-e x16 slot, i can't use the x8 slot on my board since it will block the Duorb fan of my vid card. These are the cards i was considering:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816115050
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16816118058
http://www.newegg.com/Product/Product.aspx?Item=N82E16816103050
http://www.newegg.com/Product/Product.aspx?Item=N82E16816103085
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16816116064
http://www.newegg.com/Product/Product.aspx?Item=N82E16816118061
http://www.newegg.com/Product/Product.aspx?Item=N82E16816118084
