PLZ help me upgrade
TommyT
Been out of the loop for a while and want to upgrade my sons computer for Christmas.
He plays World of Warcraft and Counter Strike mostly.
Would like recommendation for the best combination of a new Mobo w/sound and must be IDE compatible, Processor AMD or Intel okay, Ram and GPU.
My budget is no more than $800.00 for these 4 items.
Thanks,
TommyT
option 1
motherboard: $100 Foxconn P9657AA-8KS2H
processor:$309 Core2duo e6600 2.4ghz 2x2mb l2 cache
ram: $200(after $32 MIR) 2gb OCZ PLAT REV.2 2gb DDR800
graphics card: $280(after $20 MIR) HIS x1950xt with XTX cooler
TOTAL= $790 w/(MIR) $842 w/o MIR
option 2
processor: $181 Intel C2D e6300 1.86ghz 2x1mb l2 cache
ram: $100 Wintec ampo 1gb DDR 800 (2x512mb)
graphics card: $430(after $20 MIR) EVGA 8800GTS
TOTAL= $811 w/MIR $831 w/o
A couple of options, option 1 gives you a well rounded build but option 2 does give you directx10 with a sacrifice on the ram and processor. Your choice :)
Since WoW and CS arent very demanding games, you really don't need an 8800 card.
Is it late or is my math wrong? 100+310+200+280=$890 ... b0b?
I think you'll have to stick with the E6300 instead...
$181 - Intel Core 2 Duo E6300 Conroe 1.86GHz
$100 - Foxconn P9657AA-8KS2H Socket T (LGA 775) Intel P965 Express (review)
$200 - OCZ Platinum Revision 2 2GB (2x1GB) DDR2-800 OCZ2P800R22GK ($240 - $40MIR)
$240 - BFG Tech BFGR7950512GTOCE GeForce 7950GT 512MB ($260 - $20MIR)
$721 + tax and shipping (after rebates)
If tax and shipping (or the rebates) make that build overbudget, then go for one of these instead:
$200 - Sapphire 100176L Radeon X1950PRO 256MB
$681 + tax and shipping (after rebates)
If you can afford the XTX, go for it:
$280 - HIS Hightech H195XTQT256DVN-R Radeon X1950XT 256MB ($300 - $20MIR)
$761 + tax and shipping (after rebates)
Remember a power supply.
Try the Ultra X-Finity 500w that's for $35 after rebates at ZZF.
The E6300 or E6400 would be enough to run CS and WoW. No need to have an E6600. You could also switch to the P5B-E board too, $50 more, but that is preference.
Make sure you look into motherboard options. The foxcon linked only has 1 IDE port. All the Intel 965 have no onboard ide, and manufactors are adding just 1 slot for compatibility reasons, mostly optical drives. So if you got IDE opticals and IDE HDD;s, that mobo may not fly.
that's what I get for doing it in my head even though I was doing yr11 Maths B (hardest maths) now I'm on holidays :p
but I'm glad you liked my parts selection :p
Hehe, holidays? i usually cant think by the end of the day, lol, not just holidays, haha. great choice of parts ;)
The asus p5b-e isnt worth it. If you need more EIDE controllers, get a PCI IDE Controller card. I use a Promise ULTRA133 TX2 for my extra IDE drives in my server, and it works great. Intel is phasing out IDE from their chipsets, so any intel chipset based board will most likely have only one IDE controller for 2 PATA Devices. Any board with more than 1 is using a 3rd party solution. Instead of paying more for such a board (MSI 975X Platinum/Asus P5W DH), you're better off goin with the extra PCI card.
Another choice would be to wait for the nForce650i SLI/Ultra boards, since those chipsets support 2 IDE controllers. However, I'm not sure it will be on time for Christmas.
Thanks guys... trying to keep this thread on track. Yes, the other hardware is all IDE. Drives and all.
Have 2 160 Gb IDE drives on raid controller and CD/R and DVD/R on the two IDE channels.
Thanks,
Tom
