Plumbing Advice Needed
qdemn7
OK I need advice and criticism on my W/C setup. This will be my first W/C rig, and a learning experience.
It will be on an NF3 ‘board for now then transferred later this year, to an NF4 (non-SLI) board. I don't want to carve up my Gaming Bomb 2 case for a dually radiator.
AOpen AK89 Max
A64 3000+ Newcastle (currently running at 2.35 x 10 @ 54C under full load)
1GB OCZ 3700EB
BFG 6800GT w / NV5 Silencer ( 72C under full load )
1 x 300GB Maxtor SATA
NEC 3520 DVD Burner
Antec Neopower PSU
Gaming Bomb 2 case
Cathar's Storm Waterblock
Danger Den Acetal MAZE4
Danger Den DDC-12V
Danger Den Bay Reservoir
PolarFLO TT VGA Block (for chipset)
Glacial-EXM Dual Pass 120mm Radiator
Anything wrong with this routing? I plan on running:
Radiator
Reservoir
Pump
Storm
Southbridge chipset
NV-68
Radiator
Then I want to know is this:
Since the DDC pump has fixed 3/8" outlets on it, what should I do for the plumbing aspects?
(1) Should I run entire system as a 3/8” system?
(2) Fit the outlet of the reservoir to a 3/8” fitting then to the pump, a 3/8” inlet on the Storm, ½” outlet on the Storm, then the rest of the system ½”? (I’m getting two complete sets of barbs sizes with the Storm.)
(3) Other options
Any advice is welcome. Thanks.
EDIT: to add system
If you can i would go:
Reservoir
Pump
Radiator
Storm
Southbridge chipset
NV-68
Reservoir
That is simular to how im setting mine up but i am going to put in an extra radiator inbetween the cpu and chipset.
You could do it either way:
rad-->res-->pump-->block or res-->pump-->rad-->block
There is a not much of a cooling difference if you put the rad or the block in fron of the pump.
I guess whatever route is cleanest in your case.
Also maybe a larger rad if you can since you will be cooling 3 waterblocks.
route it whatever way is easiest to run the tubing, it won't really make any difference in the end because your water temp isn't going to increase by a whole lot in the .025 seconds that it's sitting inside the waterblocks in between components. you can pretty much assume that the thing is like a big circuit and no one piece is going to get significantly higher or lower temps than any other piece unless you're using a ginormous radiator or res.
i recommend option 1 because it's the least complicated and won't make much difference anyway.
Run the whole loop 1/2" tubing.
Buy or find a couple inches of 3/8" ID 1/2" OD tubing. Put a short piece of the 3/8" tubing on the DDC's barbs, then slip your regular 1/2" tubing over the 3/8" and clamp them both down. :)
you should do whatever gets you the shortest lines. it's good to have the res before the pump tho.
In reading several other threads, there seems to be a consensus that 7/16" with a 3/32" wall makes a great middle ground for 1/2" and 3/8".
