Plugged in or not?
CoW]8(0)
Since many video cards require an external power source from the power supply, I was curious if there was any way to tell this source is working via software (I don't have my multimeter with me).
I believe the cable to my 6600GT might be broken.
if the power connector is an ordinary molex then test that to a hdd or dvd drive
Or if it is PCI-E then it will tell you that the card is not receiving sufficient power, well at least it did when I forgot to plug in my 7800GT :p
his 6600gt card is agp because the pci-e version did not use external power. there still should be a message to alert the user if the card is need getting the required external power.
You'll get some sort of warning to let you know. I remember many moons ago, not plugging power into a 9800PRO, there was this red screen with a warning and the loudest beep I'd ever heard.
Yeah, "BEEEEEEEP"..... You'll know it. Even if it doesn't do that the drivers will pop up some sort of message on Windows startup.
Well I didn't get any beeps or messages in Windows when I completely disconnected the power connector.
What I did get was video display failure when I ran ATi Tool.
Well, there's your dead giveaway.
Well it's not as informative as beeping or a Windows notification. ATi tool usually fails after a few seconds of running the 3D cube when its unplugged.
so you been running it un plugged!?!? smart work
