Plug DVI and VGA in at the same time?
Dogmapog
Can I plug both into my LCD and switch between the two whilst the desktop is active?
You may be able to, depending on the monitor. Most monitors require you to go into the menu options to switch between Analog and Digital. Given most monitors menu setups, it's probably a bit of a PITA.
What are you doing that requires you to need both inputs?
If you need to switch between two inputs quickly, I would suggest a KVM switch.
You just push a button to switch between two inputs.
-ST-
My last three monitors have had a button that simply toggles between inputs. Right on the front.
-ST-
Yeah I've got the digi-analogue switch via OSD, but when I select it, it says no signal and auto adjusts back to VGA.
I couldn't get the monitor to work with DVI, so I used VGA, but it's a 26incher, so I was thinking DVI might be better PQ quality.
