Pls Help Me Downsize 2 SFF
gist901
I plan on basically reusing all of my current computer components that you see in my sig. I would need to replace my raid setup w/ just another 1TB Green HD. I also plan on upgrading my graphics in the coming months once prices have dropped a little bit.
I have this huge tower with a full size MB a bunch of fans, and all I have is a GPU a couple HDs. Just completely unnecessary in my words to have the CM690.
What I plan on getting for my new setup is as follows
Silverstone Sug02-BF
DFI Lanparty JR P45-T2RS5
1TB Green WD HD
GeminII S CPU Cooler
Some 80mm Fans for Cooling
My only 2 Q's would be
How big of PSU can I fit into the Sugo case? (I currently have a 500w modular PSU - don't remember the make)
Can I get away with a cheaper mATX MB - I would like to keep my Q6600 @ 3.0
thanks
gist
Yeah you can get a cheaper mobo...775 is old news. Anything between 60-100 will do
You can get a 160mm PSU fine in the SG02 and this is all you really need...No way on earth you'll need more than 750w. You can use a PSU over 200mm easy. NO issue there at all.
Virtually anything with a G31, or G35 chipset will serve you well.
A 3Ghz clock on a Q6600 is easily obtained by the most neutered motherboards.
Edit: Sorry I missed the RAID spec. If that's really necessary then your options are sort of limited.
Edit2: There, or check ebay, the sale sections for motherboards with ICH9DO, ICH9R, ICH10DO, ICH10R southbridges.
hey thanx 4 the response, its good 2 know what chipset 2 look 4 in my MB.
As far as the RAID, don't worry I already know that has to go.
gist
PS - time to start spending :D
gist
Time to start SPELLING. you would have to hit two extra keys to spell out for, and ONE extra key to spell out to.:rolleyes:
