Hi,
i'm looking for a replacement of my Nec MultiSync LCD 1990SXi which i sold because i need more screen space. At the moment after glossy displays wide gamut is the next hype but i think those are wrong for me.
I had a HP LP2475W but had to return it because he wasn't ok. The colours were a awful. I'm afraid that the only monitor which will look good to me is the NEC 2490Wuxi because i'm used to the light sensor and the perfect colors of my sold NEC 1990SXi.
At the moment i'm on a borrowed Philips 220WS and i think the screen is width enough but the height isn't that more as it was on my 19" (sure 1024 compared to 1050 of the Philips). So it's a funny feeling because it looks stretched and that was it.
There's another problem -> I spent a lot of hours in front of my Computer (Macbook Pro) so ergonomic counts and i don't know if i want a black frame as my Nec was a silver one.
My main usage is slicing templates for websites and coding it's xhtml code and i also use it for my university study. I'm afraid that 22" will be not enough in height because it's not really more as it was on my NEC (i mentioned it above).
So main usage:
-> Web-Graphics / Coding
-> Reading/Writing papers for university
The NEC 2490wuxi will sure be a perfect display but i don't use it for what it's meant to be (professional graphic display) and it's very expensive. I thought of a NEC P221W but it's only a 22" or a Dell 2209WA.
Do you have any idea what i should do?
So main usage:
