Just to let you know that error in the beginning is telling you that your cpu fan has failed and your computer is failing to boot up likely because its overheating. Is your system o/ced?
If you receive this error message, the file listed in the error message is corrupted.
He is actually using a watercooling system so there is no fan to power for the system. Hence the error.
I have seen something like this before just have to remember what it was........
STOP: C0000221 Unkown Hard Error
\SystemRoot\System32\ntdll.dll
corrupt ntdll.dll file?
edit: per MS KB 101096 (http://support.microsoft.com/?kbid=101096) it means, yup, ntdll.dll is corrupt
Just back up your files then reinstall XP. You don't need applications to launch to back up files, and you don't have to buy a new OS.so. I did the repair install which got her up and running but it came with some other issues.
I'd say over half my apps from browser to games etc crash upon trying to start them up.
then I get some error message about the app not being a value windows dll or something like that.
sigh. I guess nows as good a time as any to start looking at a new start with vista
Well you're really lucky! Good move on that. What are your system specs? Vista can be picky and it's hit or miss with how people like it. Fortunately I've had amazing results with it and love the OS but I can't say I 100% recommend it.fortunately I never keep important files on the same hdd as my OS. files are all in a seperate My Docs drive and then backed up externally.
I'm just whining about reinstalling xp. definitely considering vista tho.
i'm still using DDR1 (2GB) and a dual core opteron 175 running at 2.8GHzWell you're really lucky! Good move on that. What are your system specs? Vista can be picky and it's hit or miss with how people like it. Fortunately I've had amazing results with it and love the OS but I can't say I 100% recommend it.
y'know - i kinda was thinking the same thing at one point...Sounds like a faulty hard drive to me.
