So I had a horrible Gigabyte boot loop issue yesterday (spent all day trying to solve it, finally on page 51 of a 55 page thread found something that worked) anyway, I am not going back to "testing how far I can push my system" instead I am going to go with what I know is stable, 4.4 ghz.
Interesting issue came up though, originally my settings were on AUTO PLL Overvoltage and I read in a few places to turn it to disabled if not going 4.5 or more, so I did that this time.
Results when PLL overvoltage was set to Auto:
Needed to set my Voltage to normal and Dynamic (I guess its the same as offset on other boards), the strange part is with "offset" people always have low values but I had to set mine to +0.125 to get it to run at 1.296-1.308V while running tests, it maxed at 1.332 at times, then down to 0.996-1.116 at idle (pretty huge dips, probably due to offset/dynamic setting).
THEN, after finally resetting Bios after boot loop, I flashed the same Bios I was using on previous overclock but this time turned PLL Overvoltage to DISABLED instead of Auto and now I am seeing these results:
Dynamic/offset setting is +0.010 (I used the 0.125 at first and voltage spiked to over 1.4v so I knew something was off), I am getting the same 1.296-1.308 now with this 0.010 offset and haven't seen anysort of peak (when I first tested 0.025 offset there was a peak slightly higher than the normal range during testing, but not on the 0.010 offset so far).
So does PLL overvoltage cause Dynamic/offset to be messed up on Gigabyte boards (and maybe others)? I was thinking about turning it to auto and retesting, but after the boot loop issue (any familiar with it will know why I don't want to go through that again) I don't really want to mess with Voltage settings too much.
