Plextor 716 sa
jerswerve
I just purchased a 716 sa expecting good things...one problem...it appears my MSI K7N2 Delta will not support...anyone have a fix?
Yes, more info please. You may need to enable your SATA ports in the BIOS if this is your only SATA drive.
yes, of course I have SATA ports. I have a WD Raptor connected to one of the ports. Whenever the Plextor is connected I post fine, then before the XP flash screen comes on I lock up...nothing. There are no BIOS settings to change...
It doesn't seem to work with very many MB's or controllers yet. Here's Plextors compatibility list . You might want to check out the Plextor forum over at cdfreaks.com
I have had a similar problem. It seems as though it has to be on a different controller all by iteself or something and it can't be on a controller where RAID is enabled.
Here is what I found with my A8N-SLI that has both the nVidia controller w/4 ports and a Silicon Image controller w/4 more ports:
1. Enabling RAID on the nVidia controller w/the Plextor connected to one of the ports would generate lock ups like you describe. But if I did not enable RAID then it would work fine.
2. If I placed the Plextor on the Silicon Image controller w/o RAID enabled then it would also work.
It seems it has issues not only with specific controllers but if RAID is enabled on channels that it is not even using.
Guess this is what we get for being on the edge of technology w/the new SATA optical drives.
