plexi question?
Drunkinsquirl
what kind of adhisive should i use for plexi, is there something special i have to use, i know it is kind of a noob question but i just wanted to be sure
I believe what you're looking for is called Weld-On #4. I may be wrong, but look into it
most hadrware stores that sell pelxi, will have the 'glue' that you need, and it should be right there with the plexi, if you dont see it ask the clerks i know at least at Home Depot and Lowes they know what you need and where it is.
Plumbers Goop works pretty good for bringing joints together, buy if you have large surfaces areas to bond, you will want to use an epoxy as other sealants need air to cure.
