Please suggest a good PCIe mobo
CDdude55
I am soon going to upgrade from my AGP board and going to PCIe but i need a good board.
1. AMD
2. Ether one is ok
3.I may use SLI some day.
4. I might keep the hdd and the disk drive.
2. Ether one is ok
Nvidia has SLI so these two points don't go together.
Since your HD is already SATA, this isn't important as all boards have at least one IDE channel. Also, if you're gonna use SLI (or Crossfire), you need a board with at least one PCI connector far enough from both PCI-E x8/x16 ports for your X-fi soundcard.
I'd reccomend Asus M2N32-SLI Deluxe for the SLI option or perhaps Asus M2R32-MVP for the Crossfire solution.
If your using your ddr ram then 939 would be your choise and an asus a8n 32sli dlx board is about the best board out. Another choise would be the a8n sli board but they are getting hard to find. If you dont think you will go sli on this platform then thr asus a8n-e ultra is a fine board.......If your going with a complete upgrade with ram then am2 is the choise and the above mentioned boards by ijozic are fine,also the abit lineup for am2 is also very good.Look at newegg for the abit lineup as its pretty impressive price wise and performance wise. I personally like the abit lineup better than some of the asus boards for am2....
