Please suggest a flow meter & temp sensor...
undertheradar
For my water cooling setup which uses 1/2" ID Tygon and an eheim 1260. I would like something that tells me the actual water flow if possible. I am also looking for a temp probe, but that could be something seperate I suppose.
RedRaider
I use the BitsPower Temp Sensors...
You can Find them here at Sidewinder Computers
vengence
Level capped
http://www.sidewindercomputers.com/viflinwi1idb.html
^^^ Found that... I just dont care for the 'paddle wheel'... dont think it provides any real flow data, and it most likely restricts the flow a bit.
I have the same concerns with this one...
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=239&products_id=24531
IMHO, I would think they would be negligable on the flow restrictions. The only force your applying to the paddle wheel is going to be enough to overcome the friction in the bearing and the inductance to the sensor.
Arcygenical
Koolance has a great new flow meter, it's doing a fantastic job in my loop.
But, that probe RR linked is what I'd pick for the temp sensor as well.
