Hi,
I was wondering if I could get some tuning help. I’ve been in computing for about thirty five years and have a lot of software and hardware experience. At the same time I don’t pretend to know all the details of this. I have a brand new very complex system and it hangs or crashes about once a day. The system will run complete superpi without errors. It will pass one pass of the Vista extreme memory tests which is quite a battery. I let it run two passes over night and it hung on the second pass so the system is still not stable.
OS: Vista Ultimate 32 RTM
My hardware configuration looks like this:
CPU: Core-2 Duo Extreme x6800 – currently not overclocked – Aircooled Temp 44 degrees C at idle according to MBM5 Voltages are Asus Defaults -
Cooling: CoolerMaster Hyper 48 - (KHC-L91-U2)
Memory: 2 Gigabytes Kingston HyperX KHX8500D2K2/2g run at 1066 Mhz 2.35 volts
The board has set the latencies to be higher than the ratings, I have done very little tuning
Mother board: Asus P5WDG2 WS Professional Bios Firmware Rev 604
CPU Spread Spectrum Turned off
PSU: Antec Neo HE 550 Watts
Video Card EVGA 7950 GT OK
SCSI Adapter – Adaptec 39320 in PCIX slot run at 133 MHZ (not using raid)
Disks (2) Seagate Scsi Cheetah 15K RPM 140 GB disks in Antec coolers
Audio – Soundblaster Live PCI128
DVDs (2) Plextor 755-SA (Sata)
Turning CPU Spread spectrum off made a huge difference in stability. When it was on, superpi had rounding errors in the first iteration. Turnng it off superpi will complete out to 32 million places routinely without error. Superpi in no way saturates the two cores when it runs.
CPU-Z Report
CPU-Z version 1.35.
CPU(s)
Number of CPUs 2
CPU#1 APIC ID = 0
Name Intel Core 2 Extreme X6800
Code Name Conroe
Specification Intel(R) Core(TM)2 CPU X6800 @ 2.93GHz
Family / Model / Stepping 6 F 6
Extended Family / Model 6 F
Package LGA 775
Core Stepping B2
Technology 65 nm
Supported Instructions Sets MMX, SSE, SSE2, SSE3, SSE4, EM64T
CPU Clock Speed 1602.7 MHz
Clock multiplier x 6.0
Front Side Bus Frequency 267.1 MHz
Bus Speed 1068.5 MHz
L1 Data Cache 32 KBytes, 8-way set associative, 64 Bytes line size
L1 Instruction Cache 32 KBytes, 8-way set associative, 64 Bytes line size
L2 Cache 4096 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1602.7 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
CPU#2 APIC ID = 1
Code Name Conroe
Package LGA 775
Core Stepping B2
Technology 65 nm
L2 Location On Chip
Mainboard and chipset
Motherboard manufacturer ASUSTeK Computer INC.
Motherboard model P5WDG2 WS PRO, Rev 1.xx
BIOS vendor American Megatrends Inc.
BIOS revision 0604
BIOS release date 11/30/2006
Chipset Intel i975X rev. C0
Southbridge Intel 82801GB (ICH7) rev. 01
Sensor chip Winbond C1
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory
DRAM Type DDR2-SDRAM
DRAM Size 2048 MBytes
DRAM Frequency 534.2 MHz
FSB
RAM 1:2
CAS# Latency 5.0 clocks
RAS# to CAS# 6 clocks
RAS# Precharge 6 clocks
Cycle Time (TRAS) 18 clocks
Bank Cycle Time (TRC) 21 clocks
# of memory modules 2
Module 0 Kingston DDR2 PC6400 - 1024 MBytes
Module 1 Kingston DDR2 PC6400 - 1024 MBytes
Software
Windows version Microsoft Windows Vista (6.0) Ultimate Edition (Build 6000)
DirectX version 10.0
*** The cores were at idling when this snapshot was running so the clocks are the idle clock speeds.
I’m not interested in any extreme overclocking. My goal would be to run the cpu overclocked at about 10% optimized for stability and durability. I’m not a gamer. I’d really appreciate some help with the stability and tuning issues.
Thank you.
CPU-Z Report
CPU-Z version 1.35.
CPU(s)
Number of CPUs 2
CPU#1 APIC ID = 0
Code Name Conroe
Package LGA 775
Core Stepping B2
Technology 65 nm
L2 Location On Chip
CPU#2 APIC ID = 1
Code Name Conroe
Package LGA 775
Core Stepping B2
Technology 65 nm
L2 Location On Chip
BIOS revision 0604
Memory
FSB
Software
Thank you.
