Please recommend me a case for a hot climate
magnusvir
I am building a computer for my parents and I am sticking my current A64 2800+ and chaintech vnf3 mobo in it. I will also have a Zalman 7700 attached to the A64. There will be only 1 hard drive and a cd drive.
The climate out there is quite hot. Ambient temps range from 26 degrees celcius to 34 degrees celcius so I need a case that will keep the rig cool as well as be able to fit the zalman. I was looking at the Sonata but I dont think the Zalman will fit. I also dont want the Thermaltake ones as they are too pricey and I dont need the benefit of 5 drive bays and such.
Any suggestions?
i think that getting a special case for this build is a waste. a plain beige case with 2 80mm fans in the back, and maybe another in the front should take care of a computer that is not being OCed, with a beefy heatsink in there on top of that.
if you really insist on adding extra cooling, then i guess that it depends on how cheap you are, and how much time you have during exam break. i am a big fan of modding a cheap steel case to accept 120mm fans. one in the side, right over the proc, and maybe a second as a blowhole, venting heat out the top along with the PSU. if the drive and vid card are unlikely to get hot, then that should do it.
Chenbro Gaming Bomb 2. And newegg has it $100 cheaper then most, in brushed alu and black. 120mm in front of HDD cage, 120mm on back, 92mm top exhaust. HDD cage can be installed in any direction. Tooless. 1.2mm Alu will never warp. Vents for fans made properly, very quiet and almost no restriction.
I mean this things airflow is sick, easily within range of BTX specs, and its cable management system makes keeping your cabling tidy to near invisible a snap. They had them at quakecon and its very very nice, kept a 3.2E prescot at the hall's roomtemp easily with doom3 demos running.
$210 at the egg tho, and no PSU, not that you'd want what chenbro puts in its cases normally.
Just get anything with a 120mm exhaust for cheap and be done with it.
