Please Recommend a Mouse Like Mine
Hulk
I currently own a SideWinder Mouse that is 10+ years old. I recently got a laptop and would like to buy a mouse that is just like my current one. As you can see, this mouse has been discontinued. Any advice on a mouse that is very similar to mine? It can be either corded or wireless.
https://www.amazon.com/Microsoft-HK...332&sr=8-3-fkmr0&keywords=ms+sidewinder+mouse
EDIT: Can someone tell me if the above mouse is a "finger tip" or "claw grip" mouse?
Check out this guide:
http://www.rocketjumpninja.com/find-a-mouse/
There are several mice I've scene with similar shapes like yours. Best to follow the guide above to find your grip style / hand size and go from there :)
Reminds of of the Razor Naga, MM520.
Check out the Rival 310 or the DeathAdder Elite tho
I use a Razer Elite started using one 6 months ago great mouse oh and I have backups incase the damn thing breaks :D
I ran MS Sidewinders for over eight years. Had four copies, even had one on my editing bay at work. The last one failed in 2016 and I miss it horribly.
I haven't found a suitable replacement- at least for my O.J.-sized hands. I'm on a Corsair M65 now, and it's not been a fun ride.
Yar, miss my Sidewinder as well. More than anything it was its size and vertical thumb button placement that won me over.
So what does that mean guys? For those of you that owned the cult MS Sidewinder what mouse have you moved to? I love everything about this mouse, still have it, I don't know how it still works since I've had it for over 10 years and use it for everything.
What I liked most about the Sidewinder was the size. The Logitech Proteus Spectrum comes close. But I went with the Corsair instead hoping for better durability and have been disappointed.
Funny you should mention the Proteus Spectrum, I actually had it in my Amazon wish list.
I guess the IbuyPower keyboard is dieing....get the beeping and D7 postcode, no console input device found.
Plugged in the Logitech K120 and it went away....lol
Yall need to recommend me good Mouse upgrade.
The logitech g203 prodigy looks like it may be similar look and feel minus the side buttons. It has the dpi button on top to switch between 3 configurable dpi settings.
