I've acquired a FIC RADEON 9500 PRO recently. I tried to flash it's bios (no errors occured) but when I restarted my system, I HAD NO SCREEN AND A BEEP SOUNDED!! PLEASE HELP ME!!
Can't really help you there. All I can say is try blind flashing back to default bios. Either that or your card is dead. That's what flashing will do to you if it doesnt work. Hope it works out for ya
Grab a PCI video card and throw it in the system. Then remove the other card and go into the bios. Once in there set the bios to use a PCI video card before the AGP video card.
Put the AGP card back in the box and you should be able to boot with video from the pci card. Then run your BIOS flashing software and try to flash it back to the original one.
